There were 2 different cone clutch drives branded OMC but a 1988 will be the standard Cobra dog clutch. If you have it use your model number to order parts.
cone clutch drives:
All OMC Cone Clutch (Daddy King) has impeller in upper gear housing like standard Cobra, used with big block engines
Joint Venture with Volvo OMC Cobra, has impeller on engine, used from 94-98
I believe the Joint Venture (and the Volvo SX) drives use the same bellows as the standard Cobra
