So I'm reading the manual and on 5b-14 it says...
So is it supposed to be in neutral or in gear? step 1. says in forward gear but then 3 says in neutral.
Also the barrel anchor stud? Is that the black swivel piece that mounts to the engine bracket side or do I disconnect it on the carb?
Thanks in advanced!
- With boat in open water, place remote control in forward gear, idle position.
- Disconnect throttle cable barrel from anchor stud. Be sure not to lose spacer on anchor stud.
- Adjust idle speed adjustment screw to obtain 550-600 rpm, in neutral gear.
- With engine running at specified rpm, adjust idle mixture needle as follows:
- Turn idle mixture needle in (clockwise) until the engine speed begins to drop due to lean mixture.
- Turn idle mixture screw out (counterclockwise) until the speed begins to drop due to rich mixture.
- Turn screw in to a point between these two extremes to obtain maximum engine smoothness and rpm.
- Readjust idle speed adjustment screw until engine idles at 650-700 rpm in forward gear.
Thanks in advanced!
