Help me out here guys, I'm checking out a used boat, and the seller doesn't know anything about anything...<br /><br />The boat/engine looked good, it fired right up, ran smooth. Everything seemed great until I got to the prop, which just out of habit I grabbed and gave a good spin by hand. <br /><br />Oddly, the prop seemed not to be connected tightly?! I could grab two blades of the prop and wiggle it back and forth just about 1/8".. however, if I pulled outward on the prop and twisted, everything operated smoothly. IE it didn't seem to be a shaft issue.. ?! Is this something screwed up (or intentional?) in the way the prop is mounted, some kind of breakaway mount system, or..?? <br /><br />Seems like every other prop I've ever grabbed has been tightly coupled to the shaft with only minimal play... so... ??<br /><br />And along the same lines... 2000 merc 135 carbed... anything I should know / look for in particular about this engine?
