So I have the drive pulled on my 68 merc 120. The drive serial tells me the drive is a 1973 which at some point in the vessel's history must have been a replacement.
I am picking up a salvage boat (1987 or 1988 Four Winns Horizon) for the purpose of the tandem axle trailer it is on but it happens to have an Alpha 1 with power steering that I might adapt in the future. The outdrive is off but the bell housing and all other components are there. I want to use the Alpha because of the hockey puck trim and trim limit senders as opposed to the original MC-1 buried tilt limit switch that I am wrestling with.
While discussing the outdrive with the current owner of the salvage boat he tells me that the Alpha outdrive will bolt right up to my MC1 bell housing. Now I don't know if this is true or not. I am also beginning to doubt some things I thought I knew. He also keeps calling the drive Gen II. I didn't correct him but didn't the Gen II cut in in 1991 or 1992? I did print out the two different ID docs supplied by Don S (my hero) so I will have them on hand. According to the serial from the gimbal housing it is a 1988 Alpha 1.
Yoke Length: I checked the yoke length of my 1973 outdrive's gear housing. The end that goes into the coupler is 8" long. Reading through some Mercruiser literature "earlier" drives have a yoke length of over 9". When did the length get shortened to the 8 1/8" length? I want to be sure I am not risking major damage to the yoke or coupler if I am supposed to have the longer yoke.
Drive compatibility: Can I bolt up my MC1 outdrive to the Alpha bell housing without issues provided the yoke is the correct length as it appears to be?
Can I bolt up the Alpha outdrive to my MC1 bell housing without issues provided that the yoke is the correct length?
Which gasket do I use? The one that is correct for the drive or the one that is correct for the bell housing? The concern there is mating the flat top of the Alpha with the hump top of the MC1.
The motor that is in the salvage boat is a 3.7 motor which if the outdrive is correct is a 1.84 ratio. The correct ratio for the 120 is a 1.98:1. While the ratio's are close I am not doubting that the Mercruiser engineers had a reason for the drive ratios chosen for a particular motor. In some of the ID literature motors above the 120 and 140 were paired optionally with ratios 1 step higher or lower. If I am correct the ratio higher number is the turns of the input shaft. So that would mean if I use the Alpha drive on my 120 the prop will turn at less than 8% higher RPM than the stock drive. Is running this drive on the 120 going to damage the drive or the motor or both?
Like the old Steve Martin tag line "I'm so CONFUSED!"
Thanks in advance for the great help I know I will receive here
