Re: Confused by props
IF--and that's a big if. If the lower pitch will unload the engine to deliver SIGNIFICANTLY higher RPM, THEN it will deliver more speed.
In your case, the prop diameter and area was increased so the load on the engine was about the same. Therefore RPM remained the same and speed went down because of the lower pitch.
Since pitch is a theoretical measure of how far a prop will travel through the water in one revolution: Just like the car guys say there ain't no substitute for cubic inches, you can not get higher speed without pitch! That, however, assumes that the engine has the ABILITY to turn a higher pitched prop at sufficient RPM. Conversly, if a high pitched prop is loading the engine down below it's horsepower range (Not your case), THEN a lower pitched prop of the same brand and diameter will get the RPM up and the speed will most likely increase also.
Sounds like your prop engineer was talking through his A**
Want to play around a little? With the original prop: Try raising the engine on the transom in about 1/4 inch increments until you get the anti-ventilation plate about one inch above the bottom of the hull or until the prop ventilates. Once it ventilates, then drop down a bit again. See what that does for your speed. Want to play some more? Try cutting the original prop diameter about 1/4 inch smaller. See what that does for RPM and speed.
