I am trying to check the accessible recirculation valves on the V6 looper. The manual only goes through the procedure for cyl 1. When at idle I get bubbles in the glass of water from the hose removed from the no 1 cyl block that is still attached to intake manifold. I can easily push alcohol through the nipple on the block. According to manual that means cyl 1 checks good.
I get same results for the cyls 3 and 5, so I am assuming they check good.
When I went to other side of engine I couldn't get to the fittings on the block. No big deal. I disconnected hose from the nipple on the manifold. Instead of bubbles from the opening on the manifold, I would get bubbles from the hose that was still attached to block. I could not push alcohol through the nipple on the manifold (which seems correct). I haven't yet tried pushing alcohol through the hose still attached to the block nipple on the even side cyls. Guess I should go do that.
Anyway. Do I have a problem or am I doing the test incorrectly on the even side? Or is this test even meaningful other than for cyl 1? (I am using page 2-40 of my OMC manual. I am definitely getting bubbles out of the block fittings and not out of the manifold fittings on the even side.
Thanks to those in the know
Wxman
Wxman
