So I posted last week about having a loss of power in my inline 4 Merc 140. I had seen water running down the side of the engine. After removing the manifold, I found a rather large crack in the block. Compression in each cylinder was ~130 and no water in oil. I ground down the crack, and jb welded it. I let it sit for 6 days, then put everything back together. Ran fine on muffs.
Took to the lake; again it ran GREAT! We were having a blast. things seemed "normal" boat was pulling hard and all was well. We ran around for 30 minutes or so, then anchored off and ate lunch. Swam for a while then ran around the lake some more. This time I was WOT, and the tach showed about 4k when I heard a pop. It kinda sounded like a backfire... then I lost power again. Not a total loss of power, but the boat is just not pulling hard and will only do ~ 20mph. I opened the engine bay and see water running down the engine again...
WTF? If this is only the water jacket that is cracked, why the loss of power? I can not seem to relate the symptoms (loss of power, slow out of the whole, lost 10-12 mph off WOT), with a cracked water jacket. If the compression was fine (before I even knew about the crack) and no water in the oil, then the crack doesn't appear to be internal.. Why the loss of power? I'm pulling it back apart tonight.
