i have a 1983 johnson 88 spl outboard engine this engine runs great it will idel perfect when it is not under a load and it also runs great at wot ,the only problem i'm having with this engine is that when i put it in gear it will die , to remedy this the prvious owner had the engine idling realy fast , to the point that i'm worried about breaking somthing when i put it in gear, the engine will idel great as long as it isn't under a load (prop in water ).i have taken the prop off to see how the engine will act and it will idel great. is there anything i can do to remedy this ?
