I spent the entire weekend removing water soaked pour in foam from my 1990Crestliner Sabre 19' Aluminum Boat. After all the foam was removed I found dozens of drainage ports which the manufacturer installed to allow water to reach the bilge from bow to stern. Why would Crestliner take the time/effort to design/install drain ports in their boats only to fill them with foam and make them ineffective? I am certain this is the original foam. Don't know if I will replace the foam with new pour in/pink insulation/noodles/etc. Might even install an auxiliary 2000 GPM bilge pump for emergencies and forgo the foam altogether but that is a discussion for a different day.
