Hi,
I have a 2002 Volvo 4.3 GL-B, and want to connect the external tachometer I have to set the idle and check WOT because I don't trust the tach on the dash. The problem is, it connects to the positive side of an ignition coil and a ground. I don't see any exposed connections on the coil? just the grey connector. Where else would I be able to connect it? I'm assuming the wire running to the dash tach gets its signal elsewhere.
Thanks for your help.
Dan
Dan
