73 Dolphin
- Joined
- Oct 8, 2008
- 306
I have a force 125 motor and just installed a new complete NFB teleflex steering system to the boat. The OLD cable was rack and pinion and where it connected ( thru the splash well ) there was a spring loaded end that allowed you to snap on to the tiller ball mount and the sleeve sprung back holding it secure. Very nice .
The new cable does not have this handy sprung connector. Instead there's just a hole.
The question is which is the best way to connect the cable. I don't suppose that the standard teleflex cable unscrews so I can fit the adapter. I'm sure that would be too easy.
I did see a kit at the local boat place that was basically two bolts and a metal clip. Seemed a bit basic and not bearing/lube point. Also it was just shy of $50 which seemed a bit excessive for maybe $5 worth of parts.
Any advice would be well appreciated.
Thanks.
Thanks.
