Connecting rod and Main bearing torque specs AQ170C
Ray Hahn
Hi ALL, This site has helped me out alot! I have read many posts and found all the info I needed until now.
Does anyone have the Connecting rod and Main bearing torque specs for the AQ170C B30 engine please?
(I already found the head bolt sequence and torque on another post.)
Don S
Re: Connecting rod and Main bearing torque specs AQ170C
Just out of curiosity, why don't you spend 20 bucks and get a genuine Volvo service manual? You're going to need it if you ever expect to get that engine put together and running properly. There is a lot more to putting an engine together correctly than proper torque.
The manual PN is 7723640 and can be ordered from any Volvo Penta dealer.
While you're waiting on the manual, the torque for the Main is 90 ft.lb. and the rods are 40 ft lbs.
