buckwheat34
- Joined
- Jul 29, 2010
- 36
In the Clymer Manual it says" the connecting rods must be correctly oriented during re-assembly". In "figure 82" it shows a "notch up" and intake baffel to the starbord side. When I took the engine apart and dis-assembled the connecting rods, I marked them for orientation as they came out of the cylinder and off the crankshaft. On one side of the connecting rod and cap seam I have a "V" notch as shown in the picture and on the other side it has a rectangle notch. When I dis-assembled them from the crankshaft originally the rectangle notch faced up in the motor. I'm reassembling exactally as they came out of the motor, "retangle notch up". The photo shows a "V" notch on both sides of the seam. Is it correct for the rectangle notch to be up? All parts are new with the exception of the rods & caps and crankshaft. Thanks, buckwheat34
