Re: Connecting rod weight
I had a circlip come loose on piston #4. Replaced block, #4 piston, wrist pin bearing and rod bearing. When I went to bolt#4 rod to crank I couldn't get it to fit without catching my fingernail on one half of one side of the rod cap. That rod was discolored as it must have gotten very hot. Not feeling good about the fit I bought a used rod and everything seems to fit better but I'm concerned about the new rod not weighing the same as the old causing an imbalance issue. I didn't weigh them when I had the chance.
