CalicoKid
- Joined
- May 27, 2002
- 1,599
E70ELCOS I have this motor and am considering parting it out or rebuilding it and using it on my boat. I have not run it myself, just got it but the previous owner had some trouble with it recently. Without running it I pulled out the spark plugs, removed the kill tether and sprayed fogging oil in the cylinders. I put on the muffs and cranked the starter a couple times and then checked the compression cold.
#1 100psi #2 100psi #3 15psi. There is obviously a problem with #3. I know I can't get a good reading without warming up the motor but thought 100psi cold was good on #1 and #2??
My questions are: If I pull the head and the cylinders look good can I just re-ring the #3 piston or should I re-ring all 3? Should I put in a new piston? Or 3 of them? If the cylinder or cylinders are scored, how bad can they be and still be able to bore or hone them? What gaskets will I need to replace, crankcase, powerhead, head? Anything else I should be doing while the powerhead is off? I'd probably rebuild the carbs at the same time and I do like the idea of fiber reeds maybe..
There is a set of factory service manuals in a binder for this motor we just need to find them. I guess I'd like to get this motor running as easily and inexpensively as I can and not do a lot of unnecessary things to it trying to be a perfectionist if that's possible.
Any opinions or experience shared is very much appreciated
