Considering this motor
mkaminski
I found this outboard on Craiglist. The seller lives a town over from me. http://newyork.craigslist.org/lgi/boa/99639165.html <br /><br />I can't really get much more information until the seller contacts me back and hopefully I can check it out and get the serial number, etc.<br /><br />How are the older Mercury motors in terms of reliability and part availability?<br /><br />I am also concerned as to whether I'd be overpowering my 16' hull. The plate says "Maximum Horspower: 85." I'm intending on upgrading from a 35HP that only yields about 15MPH. Would looking around in the 60-70HP range be more economical in terms of carrying capacity and fuel consumption?<br /><br />Assuming I had an appropriate manual, how difficult would installation be? It seems that the ignition and remote controls are already configured. I'm mechanically inclined, but havent had much experience with outboards.<br /><br />I wasn't looking in the upper horsepower range since I figured a faster motor would be out of my financial range. However, $450 seems a little hard to pass up on a seemingly good, working motor. I'll have to wait until I see it first hand before, of course.<br /><br />Thanks in advance for any advice. :)
steelespike
Re: Considering this motor
Just a few thoughts.The Mercury motors are generally fine motors.Just get a good running test.Keep in mind any outboard will sometimes run fine in a tank or on muffs and not work correctly on a boat.<br /> The usual problem is a dirty or gummed up fuel system.<br /> Your 77 will generally get better mileage than say a similar motor from say 1965.<br /> But if you can move up to at least 1985 you will get prop rated horsepower plus an additioonal 10 to 20% better mileage.Your 77 85 hp. is probably about 80 or 81 at the prop hardly enough to notice but a little something more in 1985 or newer.Better mileage is pretty important with Gas approaching $4 a gallon.<br />If you let us know what type boat you have and how you intend to use it we can probably help you decide on a motor.
mkaminski
The boat's a 1980 Renken 157-BR. It's 15' and weighs appx 890 pounds. With the 35HP Evinrude, I have to run at WOT constantly to get a decent cruising speed with just myself in the boat. It needs extra muscle to transport 2 or more people. One time I took out two buddies who are over 200 pounds, and the motor sounded like it was going to blow up due to the strain. <br /><br />I'd like to get into the 30+ MPH range. My trips are usually never longer than 8 miles round trip. I have a 15 gallons tank. I obviously wouldn't be running at WOT with the 85, but I would always know the extra oomph would be there if needed.
mkaminski
Normally I would wait for you guys...but the seller put it on ebay and I can potentially get it for under $300. I can't lose...if it doesnt work as I would like it to I'm sure a mechanic will take it off my hands.
SeaKaye12
Heey,<br /><br />I have that exact same engine; same year...1977.<br /><br />I'm not a mechanic; but I've learned a lot about this engine in the few short months that I've had it. Feel free to ask me...I'd be pleased to help if I can.<br /><br />One thing to look out for...the wiring harness on mine was in such bad shape that I was afraid to hook up the battery before replacing it. The wires were bare in places...the insulation had just flaked off. Common; Im told. A new wiring harness is available for appx $100.00...but I took the suggestion of a few people here and just re-wired it myself.<br /><br />From what I've gleaned from those here in the know on the older stuff...the 85 is a pretty good motor...at least for it's day. I'm sure we both could do a lot worse...and parts seem to be readily available.<br /><br />Good Luck...I used to live on the Island...lots of greast boating around there. Hopefully your engine turns out to have been used only in fresh water though...that makes a big difference when they get that old.<br /><br />Thanks for reading, Chuck
mkaminski
Whoops I thought I had it...but someone proxy bid an insane amount of money! I would have paid more than what was listed on craigs list. Too bad he threw that little monkey wrench in. Thanks for your replies guys :)
timmathis
If it's in good shape looks like a good deal. Just hope it hasn't seen much salt water(Ruff on them) The pic looks O.K. but hard to tell in a pic. Tim
