Instead of winterizing I am considering using my boat every couple of weekends throughout the Fall and Winter into next boating season. I have a 5 liter Mercruiser with Apha 1 drive (carb) with an open water cooling system. My question is should I run a mixture of antifreeze and water in through the lower unit evertime after I pull the boat out of the water? I assume this would prevent freezing of any residual water left in the block between outings on the lake (Charlotte, NC area). Will regular automotive antifreeze work?
