Re: constant beeping 1999 XR6
Yeah, I noticed that this morning. I should have said that the wires went to the over temp sensors. Sorry for the error......course there is no wire attached to the stats/cover, etc. anyway.
I don't have the engine in front of me and it has been 6 months since we solved the problem and I have forgotten some of it, and it was a one time occurrence, but:
He had a dim solid alarm and dim solid warning on the dash lamp anytime the key was turned on.
There are two sensors embedded in the water jackets and each has a different colored wire.......as I remember, now that you are questioning me. Grin I guess I could drive over to the son's house and look at his engine to refresh my memory.
It doesn't make sense to me for an OEM to purchase two distinctly different parts to perform the same function. So that gives merit to the same part number being used in both sides which would yield a tan wire for both.
So it doesn't make sense to have one sensor with tan and the other with tan /blu wires. I am aware of the extra tan wire in the harness that is associated with the control box wiring. Don't remember an extra tan wire loose in the engine compartment. But that's not to say there isn't one.
We untied the wraps on the harness and followed the wires to the terminal block. Removing the wires, and ohming to ground, one had like 185 ohms of resistance (engine cold) and the other was open as it was supposed to be. With the 185 wire disconnected the horn and lamp quit emitting. A new one solved the problem.
On the sensor, this is an on-off type thing that has a trip point (195F) when you exceed it's rated temp. You wouldn't be using a rheostat for that and in my service manual for another engine it is referred to as a switch; which it is.
Maybe you are referring to a different function as you used the words "temperature gauge sensor". I can understand a sending unit for a gauge which is an analog instrument displaying a range of temperatures to be driven by a rheostat, varying in resistance and varying the current thru the meter movement as it varies.
Besides, we replaced the part and the problem disappeared as did the resistance reading.
HTH
Mark
