when i start my evinrude it will only run using the coldstart injectors (bumping the key in ) there is a constant beeping coming from the controls, the oil tank sensor is discontected, would this be a fuel resctriction warning? (engine dies after gas form cold start injectors used up) i clean the carb and when i took them off the middle one was FULL off oil....going to put them on today but was thinking it could be a bad fuel pump aswell? any help would be gretaly appriated
