Hi:<br /><br />I had a mechanical inspection of a boat I am planning to purchase yesterday. It is a 1998 Crownline 210CCR with a 5.0L Mercruiser Alpha outdrive. The boat and engine 'look' to be in very good shape but a couple of things came up. One was the starboard riser is getting hotter than the left to the point that it is somewhat uncomfortable to keep your hand on it for more than a few seconds. I believe that one (along with the manifold) will need replacing soon.<br /><br />The thing that has me perplexed is the control assembly on the right side of the engine that runs down to the outdrive is leaking salt water. When you are on plane the leak is a drop every second or slightly faster. When at idle it is a drop every 5 seconds or so. When you turn the engine off it does nt leak. Does anyone have any idea about what may be causing this?<br /><br />I informed the broker that I want this condition fixed as a condition of sale. Any help would be most appreciated!<br /><br />Regards,<br /><br />Don
