control assmbly
a1999ponyboy
hey guys i have started my restoration project. i have a 1989 raven 2100 br. 4.3l alpha1. the floor rotted and im in the middle of tear down. i have cut the decking out trom transome to the console which rotted from the bottom up. the stringers are like new in there fiberglass. (drilled cores) and the transome has no sign of rot. for th life of me i cnat get the handle off the control box! its a quicksilver with trim and "trailor" what ever that is and a newtral lock out. the set screw is removed from the bottom of the handle and i have pryed all over the thing and sugestions?
73Chrysler105
Re: control assmbly
Give it some time seems kinda dead around here today. I don't know that control so can't tell you how to remove it mine had screws on the cover and a clip you might want to look for a clip or see if you can get behind it.
a1999ponyboy
Re: control assmbly
Carholme. Is it posable for you to email that PDF to me. Dor some reason i cant downloadd it
Pmccraney
Re: control assmbly
One of those is a link to the separate remote manual for the quicksilver remote. If you can't download there, you should be able to google one up for download and it will give you step-by-step dis-assembly instructions.
That said, I think you are describing a problem I had when trying to remove a quicksilver remote from a side panel of a rotten donor boat I acquired... You pop off the plastic cap towards the bottom of the handle and you will see a head bolt in there. Its torqued on there pretty strong. You may have to pry really hard with a socket, or get a torque wrench to get it off....
When I sold my merc set-up, I just gave the buyer the remote still attached to a portion of the rotted panel that I yanked out of the boat and said "sorry I couldn't get it off; good luck to you."
Hope you fair better...
Woodonglass
Re: control assmbly
Is this the same as yours???
carholme
Re: control assmbly
Just tried the link and it works fine.
Underneath the merc controls newest manual.pdf on the left of the page, you will see Download. Click on it and when the window opens, select Free Download under Waiting time 0 Seconds and it will download it to your computer.
If you still can't get it, send me a PM with your email address.
Gerry
Woodonglass
Re: control assmbly
I believe it tilts the motor all the way up when you are ready to unload or pull out of the ramp
