Control Box 1986 85 HP Force
reppondj
Looking for a control box for my boat. Dont need the cables just the shift/throttle. Mine is pretty worn. Thanks for any help you can give.
roscoe
Re: Control Box 1986 85 HP Force
New is available here in the iboats mega mall. Used on ebay or local dealer junkpile.
Realgun
Roscoe more input. :) You need about any single handle control.<br /><br />All they do is move the shift before the throtle or if pulled out, pushed buttom, etc... Just move the throttle.<br /><br />Try This and good luck.
reppondj
The one on there now moves the shift before throttle and is pulled out for neutral and starting. No trim or any electrical on it at all. Would like to find one that will not require too awful much modification to mount......Thanks to all
Realgun
This is the control I installed. I need to updatethe webhosting showing the throttle installed. Looks good and works good to.<br /><br />Uflex 183 no tilt/trim switch.
reppondj
Thanks for all the help guys, found one on Ebay identical to mine and in great shape......
