How much slack should you see in the control box cable from a 1995 side mount control box? If I have some one hold the main control box lever and I push/pull on the cable where it connects to the throttle I see about an inch of travel without moving the handle. If I go to the other end and hold the motor end of the cable it takes almost 50%of the handle travel before the cable wants to move on the motor side. Is the cable housing just worn enough on the inside to make it this sloppy or is this normal. The warm up lever doesn't even hardly change the RPM's either. I've seen the post about pinning the warm up lever cam and I've done that. Could there be something worn inside the control box?
Bryan
Bryan
