control cables- snap in versus long life
h_lankford
stiff control cables need replacment (1986 Johnson JL60TCDS)<br /><br />manual describes both "snap in" and "long life" types of cables.<br /><br />I hate to dismantle the remote control, then have Murphy be there in full force. Then I might have a failed repair with neither the old cables working stiffly, or the new cables of the wrong type and not installable.<br /><br />so, is there a way to identify which type cable I have before I dig in? Harvey
ezeke
Re: control cables- snap in versus long life
Most, if not all, cables have the information stamped on the shielding about two feet out from the end. Give the name and numbers to your dealer and she will know what to replace it with.
h_lankford
plan to order these online. location of boat and dealer make online mor doable. <br /><br />if the numbers are worn off, then I need some other visual clue if there is any. <br /><br />If not, then dismantlement and start from there.
DHPMARINE
You'll need numbers off the cables to determine their lenght.Also may help identify the type you need.As I remember,you should have 'snap in ' type.Ready to install.Long life is for older engines,and don't have ends on them.Just bare cable,and you use the older,removable ends.<br /><br />DHP
