Controls and Motor Compatability?
levi_tsk
Ensign
Re: Controls and Motor Compatability?
yeah i dont see why it wouldnt it says 96 and newer and thats a 2000 model engine....
thats only a 25hp? the pics make it look as big as my v4 .... id wanna know what the weight is and even then id probably go for an older engine
hidef
The controls will work. The engine weighs 170 lbs it does have TNT and that adds weight do to the power trim and the heavier mounting brackets. It is a long shaft 20" not a short shaft as the add says. The oil tank and the mixing chamber is still hooked up that will need to be ditched before you run the outboard you will want to premix 50:1. The oiling system used on the small triples was garbage. Check the compression to make sure it is good and if it is you should have no problems with it.
knouse94
How much would the tilt and trim system be for this motor? Is there anyway to just not use it and change it to a stationary? I am new to the Johnsons. Thanks guys I appreciate it.
