Re: Controls work backwards
Tom, The same thing happened to me when I had the lower unit off to fix the impeller. I found that there are two neutrals on the lower unit, and I had inadvertantly shifted into the "wrong" one. The cure is to drop the lower unit again, put both the motor and LU into neutral, and observe which way the upper shift shaft rotates when it goes into fwd. Make sure the LU goes into FWD in the same direction!
