Conversion to dual Prop from single prop
denniz
Re: Conversion to dual Prop from single prop
no, the cost of the change out weighs the difference. If you want a duo prop trade up to one.
Ralph 123
What is the problem with your current setup? What is it you want? Better hole shots? Top end? <br /><br />Spending on what you current issues are there are other solutions such as a torque shift prop, hydrofoild, trim tabs, etc.
Fouled Plug
Ensign
I suppose that depends on how you want to go about it. I have a buddy with a 24' Bayliner who wanted the extra efficency and control of the DuoProp. Sold his standard outdrive, and found a used dual unit for a good price. If you shop around, and your current unit is in good used shape it can take a huge bite out of the cost.
