Re: Conversion
back with the pics. i'm not saying these parts will work on you motor, but the principle is the same. gasket for the by pass cover, 303615, gasket between by pass and fuel pump, 304784, fuel pump 438563, engine end connector 376154. you drill out the center hole and have the 2 side hole tap for 10/24 bolts, use 1 1/2" 10/24 bolts to mount the fuel pump, you will also have to have a larger diameter hose between the connector and the fuel pump. really was very easy, and i'm an advocate of keeping them original. here's a couple of pics. i can't get the second picture to upload directly of thru photobucket. send me a PM with you email request the fuel pump conversion, and i'll email direct. basicly on the lower half of the bypass cover the are what could be 3 holes in a line, you drill out the center hole, and tap the two outer.
