My fuel pump physically broke on my boat yesterday evening on the lake. I pulled the fuel pump and found the arm was broken off that rides on the cam lobe. I need to find that missing arm still .. hopefully it is in the oil pan!
I have decided to install a electric fuel pump instead with oil pressure cutoff switch.
I have a few questions and need some advice on this.
I have read I need around 3psi of fuel pressure at the carbs ? Is that correct?
I found marine fuel pumps here:
http://www.marineengineparts.com/shopsite_sc/store/html/page81.html
One is a P74021 Universal LOw pressure fuel pump 3.5 to 5.5 PSI 20-30 GPH
and the safety cutoff switch is part number A68301 on the page.
Wil this work with my AQ130D ? Will any issues happen if I use electric I need to be aware of ?
Lastly how does the low oil pressure safety switch install ? In place of the oil pressure sending unit? (I think the sending unit is bad anyway as my gage does not work)
Thank you for your help..
