Converting 200 Opti analog to digital
chadk66
I have a 2000' 200 opti that is setup analog. I want to install the digital package and the smartcraft gauges. first off can I run the SC1000 system or do I have to run the older one? If I have to run the older one I found I need the sensor/harness kit for the conversion pn-859649A2. Then I'll need the tach and speedo. What else would I need?
thanks
Fun Times
Re: Converting 200 Opti analog to digital
While that kit is pretty complete, Depending on if you went with the one or two new gauges, you would need to get either a blue series data cable with terminal resistor on both ends for a one gauge system or a blue series data cable with terminal resistor on one end or no ends for a two gauge system. The two or more gauges would also require using junction box's and terminator resistors.
I believe you'll find a lot of good info of how to set up the smartcraft system in the link below,
http://forums.iboats.com/mercury-mariner-outboards/how-install-smartcraft-system-269999.html
