Converting a Quickload Trailer for breaks
vectorrx7
I am new into Boating but I am learning how expensive it really is. I have new respect for boat owners.
I live in CT and I dropped my boat off for a new waterpump. In doing so, I was told by the employee that was checking in the boat that I needed breaks on every axle. I am not 100% sure this is true, but if it is than is there kits available that will allow me to put breaks onto the rear axle?
Capt Ron
Re: Converting a Quickload Trailer for breaks
According to the lists presented in the sticky above "Brake Law by State" if your boat's all up gross weight exceeds 3,000# then yes you do need trailer brakes. The number of axles is not specified so you need to clarify this with your state.
Tell the employee that you will take the boat to a scale and then decide the brake issue. Check for a spec tag on the axles and for a flange welded on each end just inside the wheels. If you have flanges then you can get get complete kits. No flange and you will need to replace the axle(s).
Also, if you have to replace the axle(s) make sure that you get credit for the old axle(s) if they are in good condition.
Capt Ron
vectorrx7
The book states that the boats stock weight is 2600 pounds and when looking up the motor weight I found that to be 455 pounds. This puts me over the limit by 55 pounds but I am not sure if I want to push the law for too long. I will most likely get away without the breaks for this season but I would probably fix the issue during the off season.
Is there a kit out there that would allow me to add breaks easily enough or is there alot of work in getting this trailer to spec? Perhaps its not worth it?
109jb
Yes and no. If your axle has a mounting flange for the brakes then you should be able to get a bolt on set of brakes. If there is no flange then you will also need to either have one welded to your existing axle, or buy a new axle that has them. The final option is to buy a new axle that has the brakes already installed on it.
NYBo
You may be able to purchase a kit to add brakes to the second axle. For example, take a look at the third item down:
Second axle brake kit
