Converting prop size
Blujay96
Last summer I had hswii size a prop for my 1987 v180 rinker wit a 3.0 mercruiser and he sized a solas 4 blade 19" prop. What would that convert to a hustler 3 blade prop. I am going to put smart taps on the boat also. So I am wondering if the hustler will be better with the smart tabs. My thought is I would not need the extra lift of the fourth blade. Any thoughts??
steelespike
Re: Converting prop size
I like the Hustler props but they are a really agressive prop and sometimes the 3.0
doesn't do well with them.hsiii is usually right on with his suggestions.
Any prop change is a bit of a gamble.Changing brands and style adds even more
unknowns. If your performance seems to be within expected specs now I would add the smart tabs and see what thec results are.Then make the decision on the 4 blade prop.At this point in my experience I wouldn't recommend the Hustler for your setup.The smart tabs not only improv hole shot but stay on plane with less power,
steady the ride and combat no wake speed wander.
Blujay96
Thank You I will stick with HWSII suggestion
