Re: Converting to Fresh water Cooling
Flushing an I/O is surly similar to flushing an O/B, Put it on the muffs and let it run. There are various kits with additives that you can use to flush. I have FWC so I don't really have any info. on that. In my unexpert opinion however, is that tommays is right, it's to late for an engine that old to go FWC even if it spent its' life in fresh water. Rust and scale build up will choke the exchanger quick and you will over heat and be wondering why. Do it when you are ready to re-power,(to a 350).You'll have to get new manifolds and a new engine water pump to be totally rust free, but you will get long engine life, even from a re-built engine.........J
