converting to outboard
jmlloar
Does any one know how high transom should be I'm building a new one to replace the old I/O one Any measurements would help
tashasdaddy
Re: converting to outboard
what type boat, what motor. 16, 21, 26, engine mount bracket? not enough info.
jmlloar
OK Boat was a 18' Renkin V-hull I/O with 6cyl chevy mercruiser. Transom was shot, floor around engine shot also. I removed the deck, and cut 1' down from top at the first rib. I cut rear off at front of motor well. It's starting to look alot like a bass boat. Not sure if I want to use a long shaft or short shaft engine. What I have as of now is a hull that is 14' long, just under 7' wide and 2 1/2' tall at the transom. I want to keep weight down and probably 3 people at the most. Also uncertain on using steering and remote controls or just using controls on the engine. Speed is not important.
tashasdaddy
todays standard transom is 21 inches. bottom of keel to top of transom build the sides high with a cut down for the engine, and install a motor splash well.
