Re: Cooking onboard
Same setup as 88Wellcraft. I've used the alcohol once too, to perk a pot of coffee. Took 35-40 min utes to make an 8-cup pot. I'll try it again to make 6 cups instead of 8. My impression is that it's probably better for reheating food than cooking.
I've used a propane camp stove on the boat, too. They work great, but it's another thing to store. My previous boat had a single burner butane stove that was easily transported around the boat and very easy to use, but also slower than propane. The problem is BTU output. Alcohol produces the least, then butane, then propane.
There are numerous 12-volt appliances available, but from what I've seen and heard, most don't work very well, and 'cooking type' appliances draw a lot of amps.
Anyway, give it a try- find the manufacturer's instructions on the web. If it's a Kenyon, they're located in CT and have great customer support.
