hamishmcduff
- Joined
- Jun 16, 2010
- 28
165hp inline 6 with san juan heat exchanger.
I had noticed my temps slowly getting higher and higher at cruising speed over an extended period of time.
at one point it had reached 190*+.
I replaced the impeller and its housing and my mechanic replaced a seal at the top of the water tube.
Temps suddenly dropped to 160ish at cruise, has never run better.
Started to notice a blackish water in the coolant overflow tank?
decided to drain the coolant and replace with new.
Fluid that came out was not 50/50 mixed coolant.
Replaced anyway with new mixture.
Next trip out the temp rises back up to 190ish after about 45 min.
coolant overflow tank is overflowing into bilge with hot fluid.
It would return to 160+ at idle but I could only get it on plane and sustain it for 20 min before the temp would shoot up again.
Checked the fluid in the system and it was sea water again?
Could this be the heat exchanger?
I could use some direction on where to start on this matter, my year for boating is finished now, and I would like to get things in order for next year.
