Handegard
- Joined
- Jun 16, 2009
- 102
Ok, so there is a question with the raw water system, I'll get to that.
This afternoon, went to go prep boat for a trip. Coolant on the ground behind it, and in the bilge. Crap. Check coolant cap- empty.
I stick my head under the motor, and I see a drip/drip from the plug on the bottom of the heat exchanger. Pull it out, and clean water comes out not coolant. I wipe everything with a rag, and sure enough, it drips from there still, I'm 100% positive it's not just running to there from somewhere else, and then dripping.
I filled the coolant tank and let it sit a few minutes, fired it up for a few second, and let it sit some more. No apparent leaks, aside from the raw water.
So I'm scratching my head over the posibility of a heat exchanger going bad (if it works like I think it does in my head) or what? I can't see anything else that looks like it leaks. I honestly half wonder if a disgruntled neighbor unscrewed the petcock or something.
Oh, and like I said, the boat was just sitting fine for 4-5 days, it's been moved once in that time, but only for a few feet. So why did I suddenly come home to find coolant all over?
