Simoniz
- Joined
- Dec 30, 2007
- 242
Had by 3.0l Merc out of the water for 5 months for the winter during which time the block and manifold were drained of water.
Boat went back in the water today and initially, when idling round the marina it ran a bit warm on the temp gauge (185 deg F instead of the usual 175). when I reved the engine the temperature dropped back to around 135 in seconds and so I thought it was a simple air lock problem. Took the boat out for a medium fast run and the temp stayed rock steady around the 175 mark where it always was last season. After manoevring the boat back onto its parking position again at idle engine speed, I noticed that, once again, the temp was up around the 185 mark.
when the boat was out of the water I squeezed some of the hoses to check condition and could hear/feel a crusty deposit inside the hoses. Have I dislodged this deposit and is it now blocking something like the thermostat or is it a simple air lock problem that will disappear with a bit of use.
The system quickly filled with water so I dont suspect the water pick up pump in the drive and the motor didnt overheat with hard running so I think the engine driven water circulating pump must be OK too.
Any advice please?
Any advice please?
