Cooling hose kit
flashback
I need some help with selecting which kit to get. so many different variations to choose from.. If Iboats has one, I'll get it from them, figure the least I can do for all the help I get here.. Thx
flashback
I'm a little slow today, I forgot you can't see my sig on the phone..
1995 5.7. S# 0F289690
Thx
flashback
Just looking for a set of cooling hoses for my application, seems there are many different setups. I have a leaky hose from the PS cooler to the thermostat housing figured maybe to replace all and have seen many online and all different.. the thermostat housing has 6 ports.
flashback
You may have to order each hose individually.
I just replaced an elbow and the hoses feeding the top have been replaced as they say Dayco. the fresh water input from the cooler is the immediate concern as it aged and weeping. The others are probably not far behind. Just thought I'd replace all
Ayuh,..... Ya still gotta order each one,.....
flashback
Well ain't I the lucky one! Do you guys have a suggestion and part no. for the cooler to the thermostat?
It's a tough bugger to get to being down under the motor mount, the others would be a piece of cake. I haven't cut it off yet but suspect it's 1.
25 id.. thought about getting some of the blue silicone hose, but it's pricey. Hook me up with the right part on iboats. If they have it I will purchase.
And thanks to you all, I can turn a wrench with your guidance..
achris
More fish than mountain goat
It's a tough bugger to get to being down under the motor mount, the others would be a piece of cake. I haven't cut it off yet but suspect it's 1.25 id.. .
Looks like this might be the one..
flashback
Thanks, that looks like it has the proper curves, I will need to take the old one off and get some measurements. Those folks are proud for sure... LOL
flashback
thers three different cooling systems listed links on bottom of this page , gotta look through them and see which one matched what youve got
Thanks for the link Scott,
I believe I have the gen 3 configuration and believe the hose to be 32-806856. I need to get another elbow for the starboard side so I may just get the hose at the same time from my local dealer. He's been in the business around here for a long time, good man and prices are comparable to most online dealers. Heck, he even has offered to let me try different props as long as I don't scratch-em...
