Hey all. Have twin MPI 5.0s. FWC.
boat sat in a bad spot at low tide, silt, debris etc. boat running a bit warm occasional overheating never let get above 200z
Both raw water pump housings and pulleys were wiped out. Swapped both. Did barnacle buster flush on raw water side, cleaned HX tubes.
replaced tstat and circulator pump as well, circulator was making noise. Oil clean.
Motor overheating now. It appears there is
a blockage on the closed cooling ckt. With top of inlet hose of circulator off and full of coolant level does not decrease. Return hoses disconnected as well. Shouldn’t I see the coolant being drawn in while cranking? Thanks in advance!
OW024480 SN
OW024480 SN
