Cooling Issues
loaderman
Hi everyone, im new at this posting problems thing, so , here goes.
I have a 1986 Wellcraft Sportsman with a cooling issue. It has a cobra outdrive, and 5.8 mercruiser. I have owned this boat for a few years now and i am now having cooling issues. I first suspected the impeller in the outdrive, but have now discovered another issue to question.
I removed the impeller housing to inspect the impeller (which is intact but needs replaced) and had a brainstorm, what if i put the muffs on to verify flow to the impeller. Well, what i discovered is that behind the housing the passages split, and one was holding water where as the other wasnt.
I turned on the hose to verify flow, and just as i suspected, only the port passage had a flow, the starboard seemed to be clogged.
I pressurized the muffs trying to "make" the flow push out any obstruction, but had no effect. I suspect a blockage. Am i on the right path, and if so, how do i clear the obstruction?
I really need to get this issue resolved seeing that striper fishing is here and i cant troll my downriggers without overheating.:mad:
john3931
Re: Cooling Issues
I think you would be better off posting your question in the Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives section.
