Can someone provide some info for me on Evinrude 4.5 outboard motor. It is not drawing any water thru cooling system, and overheats very quickly. I assume that there is a problem with water pump. However, I have limited experience with this type of motor. Where is the impeller or water pump located on this motor. It looks like it is on top of motor neer piston and head. Do I need to remove the six screws from bottom housing and seperate shaft and motor assembly? Any directions on how to disassemble this motor to get to source of problem would be greatly appreciated.
