saltydogjeff
- Joined
- May 12, 2013
- 145
Finally got my engine running - for like the past two weeks. I've really been bugging about the health of the engine, because all the signs point to some sort of flaw. Like, steam coming from the time valve cover therefore, coolant in the oil - check. (Doesn't mean that I am happy)
Me 24 hours ago - it is either a head gasket or cracked block.
Pumped up the coolant system with the radiator testing tool from AutoZone, 11 psi at start with engine cold and dropped to about 10 psi over 1 hour. Started the engine up, coolant pressure built up to about 7 psi at operating temp and held steady even after cooldown dropping back as things cooled down.
I was running the scenario through my head, and THINK I got it figured out this morning.
There is that area up front of the engine where the cooling pump is close to the engine oil. Like there are a couple of seals that separate the oil from the coolant. I think I am on the right track. Then I started researching, heard about this weeping hole that I was not too sure where it is located. I THINK the weep hole actually exhausts between the two seals. Its like oil][seal][void space with weeping hole][seal][coolant with pump.
I got some pictures.
I put my hand under there and find a bolt. Right in it. I got my cool but this is not cool.
Eric 3.7LX Alpha 1 , stonyloam What experience do you have with this issue? I have been reading about this thing, and it sounds like it is not too difficult but delicate in maintaining the oil pan gasket and prevention of damaging the cover when press fitting seals. Have I got this one diagnosed?
