I recently changed the impeller and exhaust gaskets (first time) after reading several threads on this forum. I fired it up today on the water hose. I let it run for about 30 seconds, with my hand on the block and heads to see how hot it was getting. I let it run until it got too hot to touch. I never saw return water coming from the discharge valve on the starboard side of the motor, just under the cowling. I didn't replace the thermostats, although I would have if I knew where they were.
My questions:
1) How long does it usually take for the water to circulate through the engine and out the discharge valve? The buzzer wasn't buzzing, but I'm not sure that it works. I don't have one of those IF thermometers.
2) Do the thermostats have to open before the water exits the discharge valve?
3) where are the thermostats?
Thanks in advance for your help.
Tregs
My questions:
Tregs
