Rattle-
- Joined
- Aug 16, 2004
- 172
I reguards to my previous question about the amount of water that should be coming out of the top hole: I purchased a set of muffs for the water-intake and hooked it up to the garden-hose.<br />Water coming out everywhere below the muffs, and thru a small hole below the prop. I can feel a bit of air-pressure, when I put my finger up to the top outlet (pee-hole) I can't get a wire down far enough thru the top hole to see if its plugged.<br />Some have said, on this site, and Johnson Repair sites, that with this year of motor, that I shouldn't expect a steady stream anyway. Can I get some help with this "possible" problem, please. Its a beautiful working motor, but I want to catch this problem, if it is a problem, before I do some damage. I've been told that there has to be a steady stream coming out the top hole. Thanks again
