duckhunter55
- Joined
- Oct 13, 2007
- 94
Alright , just replaced the thermostat and gasket and spring on my 1978 25 hp johnson. Reason for replacing was motor overheated becuase no water was coming out of pee hole. After replacing, started motor in a tank but could only get barely a mist, out of exhaust holes and nothing out of pee hole. Took t stat off and checked to see if it was getting water to it by starting with it out. No water even getting up to it. Took lower uny off and rechecked water pump and housing. Everything looked good. Clear passages from water inlet too. Impeller is in great shape, practically new. Only thing i can think of is i installed impeller wrong. Should the side with all the bronze teeth or notches be up or down. Also should the copper pipe go in the quarter sized hole next to drive shaft hole? Any other Things you guys can think of that i missed? Thanks
