Sangster21
- Joined
- Mar 15, 2012
- 130
I am nearly finished with transom/stringer/deck replacement on my Sangster 21 project. I am planning the electrical re wire and am thinking that I would like to rig up some sort of alarm for the sea water side of the cooling system. Engine is I6 with MC1 outdrive. I don't know a lot about boats, but I do know it is common for the intakes on the leg to get covered up with kelp or refuse. There will be of course a temp sending unit in engine water jacket and a gauge in instrument panel. Good, but it would be nice to find out a cooling issue before an overheat occurs.
Can I plumb in a flow or pressure sensor/sender in the raw water line from the outdrive? I believe the unit is called a Hobbs pressure switch. Where would the best location be to install the unit? I think a buzzer or bell would be the best output for such a device. Any advice would be much appreciated.
Thanks
Alan
Thanks
Alan
