timothy676
- Joined
- May 3, 2003
- 22
Well, I got my boat running ( volvo Aq131a, 4cyl) and noticed that she was smoking from the riser, well i shut it down and started looking into the cause. I'm not getting any water comming in from the outdrive, "yes I had the muffs on and water running" I pulled the cover for the impeller and and hand turned the engine and it is spinning, I ordered a new impeller online because the fins looked worn down and torn. I just worried that this is not the only thing wrong. Not sure what the part is called but it is a cup with a screen in it just above the pump, I added water in directly there and it poured from the fitting at the riser i'm gussing that is not normal since the water should flow from there back out of the boat correct.
