Have a couple ? that I'm hoping someone with more experienced then me can help with regarding the cooling system, have a mercruiser 7.4 Bravo 1 (carbed)not 100% now on the age...but believe it to be a 1990/91 Mark IV... I have new manifolds and risers (cast iron),and a brand new GM Cast Iron intake, and would like to also replace cooling systems hoses, along with a new thermo housing...my ? is the new risers (GLM) to not have the 1" water nipple only a removable plug (guessing I would have to install a nipple), my old risers were OEM Stainless with casted inlet...how important is the hose that came from the old thermo housing popet ends to the riser?? can I do away with that...it seems newer engines don't use that?? I would like to use a stainless housing that states for BB chevy I have attached a pick of my old stye and a pic of the stainless one I would like to use..
another question I have is because the old risers were the Stainless ones...the remote oil filter adapter bolted at the base of the riser....the new risers are cast iron and have long bolts that go through the top of the riser...any issue with the remote oil adapter being inverted with the filter inverted aswell....so I can bolt the adapter to the top of the riser...not sure if you guys may know what I mean on that subject???
