cooling system
JPsanta
HI . have a fiber boat , its around a 1979 , looking for a cooling diagram, engine is a 351 ford , not sure if its a commander but the exhaust logs have commander on them.there are no tags on motor or drive. Outdrive is a volvo penta. would be thankfull for all and any help
JPsanta
here are a few pics
captmello
If it is a volvo version of the 351, its model name is AQ240.
Is it overheating?
the motor or at least the exhaust has been replaced with one from Commander, which is now under the PCM umbrella. the commander motors were originally inboards used in early ski boats
the blue paint and the stainless exhaust manifolds with "commander" is the old Commander trademark
JPsanta
no , not over heating , just trying to find a cooling diagram for it , to see the water flow
Ayuh,...... Being a hodge podge of this, 'n that, I doubt a diagram can be found,.....
I'm guessing the raw water is drawn in through the transom, or somewhere in the hull, to the raw water pump, to the t-stat housing, through the motor,
n out through the exhaust manifolds,.....
But, it'll take many more pictures to see all of that,.....
the water path on the old VP drive is from the side inlets and the bottom port in the casting, water travels up the pivot shaft. there are potential leaks at the o-ring on the bottom of the hollow pin, or the raw water casting at top of the H-frame.
from there, there is a molded hose that runs to the port side of the transom shield. this is where the power steering cooler is usually mounted.
the stock volvo penta plumbing then went to the crank mounted raw water pump. however the raw water pump on the commander motor is belt driven based on the pictures. who knows how it it plumbed.
JPsanta
on the front of the exhaust manifold theres a hose that runs to the back of the manifold , why would it be like that
Bt Doctur
might find additional info on the motor at the chriscraft site
Reach out to PCM to see if they have schematics for 45 year old motors
